Old 10-09-2018, 07:30 AM
The last tank I cleaned I ended up cutting access holes into the top of it to get the varnish out. What I found that worked well was seafoam, I wet a rag and coated the inside walls. Once it sat and soaked in after a few minutes it loosened up the varnish where it wiped right off. You may be able to fill the tank with a bottle or two and soak it then shake to get most of it out but I have found that the only way to fully clean one is to get you hand in it to wipe all areas.
http://www.classicseacraft.com/commu...ad.php?t=29477
