Old 10-29-2018, 02:58 PM
SeaPlusPlus SeaPlusPlus is offline
I'm assuming you are going with a "bulkhead" boxed stringer system?
Correct! Little bit skinnier than those picture in that post you linked though. Very similar (probably exactly similar minus the bulkhead spacing) of member wgscott329's 23 restore, like this:
Plan is 2" wide 2lb density poly foam boards cut glued together then glassed in, same process for the bulkheads.
I hate how little storage my 20' has and would rather spend the $ and redo the stringers to get that additional storage below deck.
