Old 12-09-2018, 12:26 PM
Unfortunately, opening up the hatch is a whole new world. How it all started for me. Hatch needed to be recored. All fuel lines upgraded to new methanol standards ($10/‘). The “$10/gallon” rule of thumb seems to be of the Baby Boomer era, especially with new tariffs on the aluminum. Go at least .125 thickness over standard 0.90 (should in theory last longer). The foam around tank will reflect where water held and corroded tank worse than where foam was not in contact with aluminum. Cut it out using a sawsall, but be careful determining if there is a floor in the hold. My ‘79 20 had beautiful gel coat finish inside. Be careful. Otherwise, not a bad job. As said, triple your time, money and beer budget. Or BOAT: Bring Out Another Thousand. A pic may help you see how to raise, pitch console out of the way without disconnecting or removing. Hope this helps.
Vezo
Oh and the Coal Tar Epoxy
Old 12-09-2018, 12:28 PM
Two best suppliers should be RDS aluminum, Perry, Florida or Sunshine Tanks of South Florida, original builder of Potter era SeaCrafts.
Vezo.
Old 12-09-2018, 02:00 PM
Default RDS Fuel Tanks
Maybe 12 years ago I ordered a tank from RDS made to my drawing duplicating the original dimensions. Looked good and have been satisfied. However discovered the bottom had some downward bow to it due to weldng distortion. I ground down any high spots where it would sit. But also had to grind the access hatch to avoid interference with the fuel fill elbow. Also put a rubber strip around the hatch to raise it slightly. Maybe should have requested a smaller height dimension. Just FYI
Old 12-09-2018, 09:16 PM
Agreed. Once you send them the measurements, they develop a mechanical drawing, including fitting locations, email it back to confirm specifications. Once you sign in agreement, they’re building it and you’re paying for it same with Sunset, I believe, but they have specific drawings for you to approve.
Vezo.
IIRC...
Old 12-10-2018, 07:36 PM
I don't understand that. When I got my tank from them, probably 20 years ago, I told them what I had and they already had the specs. Got it shipped to me (well to a local business) and it fit great. It was already primer painted and I also painted it with resin.
Old 12-16-2018, 11:47 PM
Vezo.
RDS has the exact drawings and plans for ALL of the fuel tanks they made for Seacrafts from 1968 onward. They are NOT, however, listed by Seacraft model. Tell them the date of your boat manufacture (not the model year!), the tank model number if still available, or tank dimensions, capacity, and fill-neck location and direction. They were able to exactly duplicate the tank for my '71 Seafari for me back in 2006, and also just got one this year for my '88 18'.
The 49 gallon tank (47 gallons usable) for my '88 18' retails for about $830.
It was a bit less with my West Marine Associate discount.
Fr. Frank says:
Currently without a SeaCraft
Old 12-17-2018, 07:02 PM
Yes Sir, I have had 9 tanks built to spec, over 3 years, for Jersey Speed skiffs from them. I had no idea that they had the original specs. I thought that Sunshine Tanks were SeaCrafts number one builder. I stand corrected. I just paid $1284 for my rectanglular 70 gallon, .125 Aluminum, 2 baffles, one fill, vent, pickup, sending unit, and coal tar epoxied. Yep. Florida tax, for South Carolina pick up and deliver myself...
Shop hard.
Michael.
