Old 02-01-2019, 08:50 AM
rcnight rcnight is offline
I’m replacing the transom on mine. Decided to go in from the inside because I wanted to pull the tank as well. Cut the last 20” of cap off which made access to the tank much easier. Not sure if you can pull it without a little deck surgery. The angle might be too tight if pulling it out from the hatch. Whichever way you go, blast the foam out with a good pressure washer - makes it much easier to pull. Capt Lloyd might have better advise. Good luck.
