Anybody use these to plumb the scuppers out the back through the transom?
Thinking about trying this to eliminate the through the deck scuppers. Anybody try this with success? Looks like I could gain an inch if I fill in the pocket even with the gutters. Pics to follow. |
![]() Quote:
1971 Potter built center console. |
Yea I’ve used them through the transom on my last boat with the duckbills and they worked great. I never had water come back in those scuppers at all, drained very well.
Could you provide a source for the "duckbills"?
![]() Quote:
I attached a picture of a diagram someone else draw to help explain. I purchased the longer 4.5in model. Looking back the shorter 2.5in model would have been better to help keep the fitting higher above the water. The barbed tail end has to be floor level for it to drain properly. |
![]() Quote:
I agree. I think draining water out thru the deck might be the best option for a stock floor height. No fittings or hose to fail, simple design. The only draw back to this is you cannot add a check valve to stop water flow back inside of the boat. Most likely why people try to re-rout them out the back of the boat. |
![]() Quote:
That's very similar to the one's on my 78 Seafari originally. They always worked fine for me. |
Here are a couple pictures that may help show how I plan to do this. I'm going to glass a piece of 1-1/2" fiberglass tube to the rear pocket and connect that to the thruhull with a short piece of hose.
I thought about using the shorter 2-1/2 thruhull but I didn't think it would be long enough by the time you put the nut and pipe connector on it. My center console has twin I/O's so it's a bit stern heavy. I dont hate the thru deck scuppers but it sure would be nice to be able to use the boat without the plugs in and not have water coming in the boat. |
![]() Quote:
What if you did it this way? |
Display Modes | |
