I ordered a syphon pump, going to drain the tank and pull it. Thanks for everyone giving me input.
Been there done that. Get an old fuel pump and hook it up remotely to a battery.
Tom, does your MA have the 70 gallon option? Didn’t you have an 18 originally, or is this your first SeaCraft?
Michael. |
I have only had this boat, and the tank is undersized, the owner I bought it from 3.5 years ago told me he had it replaced and that he chose not to go with a big tank. I suspect the tank is under 30 gallons size. When I pull it I will take some more photos. I am going to reach out to RDS and see how much it will cost to just get another one same size as this one. As I dont go offshore, literally stay with a mile or two of shore. If its too expensive, I may just Redneck it for now and run a 10 gallon above deck tank. Either way I will remove the fuel and pull the old tank myself.
I’m curious if RDS comes back close to $10/gallon. Remember you will have to choose between 0.90, or upgrade to 1.25 thickness aluminum. And then coal tar epoxy.
Vezo |
Some thoughts to consider as you address the fuel leak:
That is a pretty good pile of unsecured wires sitting/bouncing on a grounded aluminum tank. At least one appears to be a large bat (+) cable; likely capable of carrying >>100A in a surge. Maybe 1/16" insulation? Most small boats do not have a large circuit breaker/fuse on the bat cables. Others wires appear to have open ends – not sure what they are. Ever see what happens to metal when a hot jumper cable hits a grounded piece of aluminum? Be safe. |
![]() Quote:
You have an original failed tank. RDS is thick wall. CG plate still on the tank? |
About 15 years ago I replaced the 47 gallon tank in my Seafari with an RDS tank of the same dimensions. Seemed like a good idea at the time. Now with only lake use and with an ETEC which is not as thirsty as my Merc V6 150, almost wish I had gone with a smaller tank and gained storage area, as I never have the fuel hatch screwed done anyway. Just a thought.
Display Modes | |
