Just read through your thread, very informative. That’s a shame about your motor. But you did an amazing job on your boat. It looks great. Going to be a really nice setup with your new power.. Looks like your motor was a 25” shaft on a jack plate, is that correct? Or was it a 20” on the jack plate?
I have an 18 SF with a 20" transom and '09 Mercury 90 hp 2 stroke. Weight wise at 303 lbs it seems perfect for our 18. It will cruise all day at 25 -28 mph, plane down to 14 -16 with out tabs and top out at 36 -37 with one aboard. It has a 4 blade aluminum Apollo prop, a Doel Fin and the ventilation plate is 1 1/2" above the bottom of the boat. It previously had a '92 Evinrude 120 hp. When we got the weight out of the back of the boat and the motor height set correctly the boat absolutely came alive. Although it's not a rocket ship it's nicely balanced, great in a head sea and economical to run. Best of luck!
Rod
The older I get the faster I was! |
"BTW, the F70 and F90 are exactly the same in terms of weight, dimensions, etc. Only difference, I believe, are the stickers and ECU...and the price"
Not true, the 70 is 1000cc and the 90 is 1800cc, the 90 is much heavier, 100# more. The 70 is only available in a 20" shaft and the 90 comes in 20 or 25". The 70 is basically a motorcycle engine with great HP/weight ratio. It was designed for the 16 to 18' technical skiff market. https://yamahaoutboards.com/en-us/ho...15-50-hp/70-50 https://yamahaoutboards.com/en-us/ho...115-50-hp/f115 |
#24
Real quick, back on post #7, the Optimax I mentioned is a 1.5L 3 cylinder for both the 115 and 90, they weigh the same. If they are still available the 115 Opti would work nice on a 18' SeaCraft.
#25
My '75 18 footer had the 20'" transom. Back in '02 the Suzuki four strokes hadn't built up a reputation yet, and I found a 20" DF 140 that the dealer wanted to move. This was in the West Palm Beach area, where there's a good deal of flat water on the Intracoastal and sometimes outside, so you have an opportunity to run fast - but also occasionally pretty rough inlet running and ocean seas. My boat didn't have trim tabs, and don't remember checking low speed plane, but I don't recall feeling that it was an issue. I did however scare the living heck out of myself the first time I tried backing down on a fish out in the open ocean with a little sea running (the boat didn't come with washboards). In short order I made up some hinged boards out of Starboard, which allowed the motor to tilt when folded, and they helped a lot in keeping water out of the boat. I knew the motor put a bunch of weight aft, so I moved the batteries under the console and tried not to load heavy gear in the stern. As Don said a few clicks back, it's a good idea to first try to figure out how you're probably going to be using the boat, and go from there.
1977 23' Sceptre |
#26
Torque = Hp x 5252 / Rpm (5252 is a constant) the F70 yields 63.4 ft/lbs. @ 5800 rpm, the F75 71.6 ftllbs. @ 5500 rpm |
#27
I think Terry has a 90 Etec on his 18 and it does fine.
[b]The Moose is Loose ! |
#28
#29
Some more info for the 90...
Bocaseacraft sent me a PM that said his 90 Suzuki goes 34 to 36 mph and has been averaging 6 mpg. In my book those are great numbers for an 18. |
#30
That’s good to know, I might send him a pm and talk to him about his setup. Thanks for the info.
