Old 04-30-2019, 07:04 AM
You can make up a few degrees with 4200.
Put a low bead down first and feather.
Very true, seen a stright swim platform on a slightly curved transom and the 4200 easily filled the gaps at the ends. They were about 1/4" at the worse part.
Also if you used washers for spacers on the thick part of the gap and none on the thin part you could tighten it down and the washers would keep the thick part of 4200 from smashing out. Once it set up you would be good to go....
