Progress three
had a little trouble with the gelling the hull. the previous owner had sanded the hull in some areas down past a layer of grey primer. unfortunately, after sanding the orange peel the gray was shadowing through. bought 5 gallons of FLY gel coat and plane on regelling the hull with 2 gallons, the bottom of the hull with 2 gallons and gelling the bottom of the t top with that last of it. a engine hoist was use to raise the boat off of the bunks. worked well. dont try at home. you can also see some "fixes" the old owner attempted. pretty made stuff. |
progress 4
ended up grinding out the pool of thickened polyester for the delamination on the bow. decided to fill with 1708 + three layers of mat. |
progress 5
should have boat all gelled and sanded this weekend. |
