Old 08-28-2019, 02:34 PM
FLexpat FLexpat is offline
Since that is a FG bracket you might be able to notch it just a bit if you only need an inch or two. The single should weighing a bunch less should have it sitting higher in the water than the twins did. You would need to check and make sure the motor would still tilt all the way up without binding though.
