Old 09-12-2019, 09:32 PM
Glosta23 Glosta23 is offline
DonV - I looked at the link you shared and also the IG thread seacraftrenovation72. Great info and photos! Thank you.
A question I have is; why did you opt to entirely remove the stringers as opposed to cutting off the tops and hogging out the foam?
Old 09-13-2019, 08:44 AM
Default Estimating CG changes
Glosta23-
With all the changes you are considering you may want to consult my post of ESTIMATING CG SHIFT....... it is in a sticky. Original post was 9-24-16.
Best wishes on your project.
Old 09-13-2019, 11:25 AM
Glosta23-
This is the best advice you'll read here based on your plans.
Old 09-16-2019, 04:59 PM
Thank you Capt. Terry. Great info and I'll be sure to do my calculations before hanging anything on the transom.
Old 09-16-2019, 10:45 PM
Default Predicting CG changes
You are most welcome. I suspect others have been intimidated by the math or just decided to wing it. I made it as simple as I could- just plug your numbers in for mine. Certainly should be better than guessing. Best wishes and looking forward to results.
