#51
Just curious, do you use the Raka UV for other phases of your boat building? I just received my order of this with enough to do my transom. We have wild temperature and humidity swings here in LA (Lower Alabama) this time of the year, so I was thinking that this may work pretty good for me.
#52
I will use some of the UV to rebuild the teak anchor locker door though. Then itll be clear coated with awlgrip or similar. Im gonna do a couple “pours” in a shallow tray to glue all the pieces together and leave a nice flat face... |
#53
With my limited experience,these are valuable time saving tips to help keep me on the right path. Thanks, and keep us all posted with your progress.
#54
Any questions just ask! Probably used 500 gallons of their stuff over the years
#55
We will see how this armstrong hatch works out. The smaller ones seal great.
![]() ![]() Bottom side is glassed ![]() Gutter will drain to recessed side scuppers. Theres a 1/2" of crown in it. ![]() ![]() ![]() |
#56
There sure is a lot to learn from your posts Dirt...I'm sure the armstrong deck plate will work fine never had a problem with any of the ones I've used...never did the recessed receiver like you have done... its nice to see you are always going he extra mile
![]() strick
#57
How big is the Armstrong hatch? I would like to buy 2 rings like this for my bracket if they were 8 "
#58
That's really slick!
#59
They call it a 10” but the clear opening is 10.5 and the OD on the top is 12”. The “mold” was just a piece of 1/2” starboard cut to a 12” circle on the bandsaw. Put a small roundover on the top and some clay in the corner and lay it up
#60
Test fit. No patterns, just width measurements every ft then every 6" up forward... The crown will get persuaded in with some weight. Outer stringers are 1/2" or so lower than inners, a good 3/4" at hullsides. I hate standing water!
Its only got 1x1700 on top now, the second will cover everything and tab into the hullsides. 85# as it sits right now If it looks funny its because the vertical lines in the bulkheads arent centerlines, theyre just glue joints... ![]() ![]() ![]() ![]() |
