Thread Tools | Search this Thread | Display Modes |
![]() Quote:
I switched to a 3B Mirage 17P. Top speed was 42 knots, would hold plane down to about 13 kts and got on plane very quickly. Got a chance to talk with the guys at PowerTech and bought an OFS 4B 15.5x15P. 1 knot slower than the Mirage, but even better holeshot, much better low-speed control and would hold plane down to 10 kts. Max RPM fell to 5650. After a couple of months and lots of emails, I traded that back to PT for a one-off custom-built (read non-returnable) Power Tech OFS 3B 15.25Dx16.5P with extended tip cupping because I ran with my motor mount as high as possible. Top speed was now 46 knots at 6050 rpms with light fuel and one person on a cold day. When I put the bimini up and loaded the family top speed was about 42-44 kts, depending on conditions. Time to plane about the same as the Mirage, and would hold plane down to 11 kts in calm water. Ran best in a light chop. Man, I LOVED that prop! Swapped the Merc XR motor for a 90hp Opti in '06. Top speed fell to 34kts, but fuel economy went from 1.9 NMPG, to almost 6 NMPG average. Partly because I wasn't tempted to run at 5800-6000 rpms all the time.
Snookerd, Regarding point #2, which was better? Can you give me some more details on that (without upsetting anyone). I am currently planning a 23SF resto, bracket with twins is the current plan. I have read a ton on this site but have not yet taken a ride on one.
I need to find someone in NJ with a 23sf and bracket with twins. Thanks |
![]() Quote:
Snookerd |
![]() Quote:
It's probably obvious, but thought I'd throw in that in addition to the difference in balance point between the Sceptre hull and a CC that Snookerd mentioned, the "moveable ballast" - people and gear - are typically also further forward while underway in a Sceptre than a CC. People at the helm, and junk in the trunk. We get on plane very easily and quickly, running just a Merc 150 4 stroke on an old non-floatation Armstrong bracket. I haven't tried to pin down exactly how slow it will maintain plane - fixing the trim tabs hasn't made it to the top of the list yet.
1977 23' Sceptre |
Twins on a SF with a bracket would worry me with stock deck heights.
[b]The Moose is Loose ! |
Display Modes | |
