  #35
Old 12-03-2020, 02:40 PM
jtharmo jtharmo is offline
You sure? I thought they injected the oil in specific areas of the engine and it's not all mixed with the gas. It may not be high pressure like the fuel injectors, however I would think the oil has to be under some pressure. I'll ask my brother how/if his 250HO registers that info on his MFD. Again this is from memory that a BRP dealer/salesman told me at a boat show....I've burnt a bunch of brain cells since then.
E-Tec's have an oil pump with an integrated pressure sensor but it isn't a constraint pressure pump like in a 4-stroke. They use pulses to push oil to points around the engine I assume in coordination with inputs like rpm, fuel flow, etc. I think the oil alarm is linked to rate of actual pulses compared to what the EMM wants. So in a long winded way, I'm saying real-time oil pressure on an E-tec isn't very helpful.
