I’m about to remove my cap on my 23 and while it’s off it would be easy to pour some foam in between hull and cap. Any issues with this ? Trying to cut down on noise and vibration .
Thanks, Kevin |
Pour it in the crack and no telling where it will end up...I would not do it unless I was certain it was going to stay between the hull and liner.
Ditto!
Where else could it go ? I’ve already foamed in between hull and stringers. I would think it would hit bottom and then come up and out . Or is it even worth filling such a small void.
I can certainly see it helping... if it works
It’s a lot of work separating the liner from the hull to put some foam in between and then use hull and deck to bond the two back together.
Definitely not separating anything. Drill holes near top edge and poor in foam with funnel then epoxy holes .
Where’s your sense of adventure? I think it was gusting over 20 the day I glued it back in.
While filling a lobster boat keel, with a form capping it, the 2x4's began to bend and before they blew through the cabin top someone smashed them free with a long handled sledge.... The other time, someone shot some in the topsides of an old mako during a repair, and it resulted in a huge split in the topsides. Additional rework time was needed to fix that big mistake |
