Old 05-12-2021, 06:57 PM
Rbphipper Rbphipper is offline
Looking good Scott!
Old 06-04-2021, 03:15 PM
Scottman Scottman is offline
Two down, two to go.
Old 06-12-2021, 02:10 AM
AyeSpy AyeSpy is offline
Looks great! I am also using Coosa but I am going to move my drain hole from the port side and center it to just behind the keel. I am putting in a Coosa knee to span the small amount of space between the keel and the transom. There is probably a thread for it, but has anyone you know of done that? I'm just tired of the mosquitos having sex in my boat!! If I can't, well...
Chris
Old 06-14-2021, 09:34 AM
I don't have a pic of the knee, but, that's precisely what I did.
http://www.classicseacraft.com/commu...1&d=1623677646
Old 06-14-2021, 04:01 PM
steel686 steel686 is offline
I wanted to center my drain as well and put in a knee with the new transom. The one thing I didn’t consider was bilge pump placement. I had to make a block to mount the pump base adjacent to the knee so it isn’t as low as I would like. Doesn’t show in the picture being on the starboard side. Something to consider.
Old 07-08-2021, 06:53 PM
Hi Scott, I've been following your thread. Where are you at with your project? Did you decide on tank yet?
Old 07-08-2021, 09:57 PM
Default Summer off
Stopped working on it till the fall. I am out on Block Island and sure enough there is a 20SF a couple of boats away that is finished out pretty much the way I am leaning towards, including the 140 Suzuki. We are both here for a while and I will go take some measurements for sighting the tank coffin, console, splashwell etc. maybe even talk him into giving me a boat ride as I have never been on one.
I haven’t tried to fair anything yet but the transom is in, the stringers are raised and I am ready to start installing transverse bulkheads in the bilge and prepping for reinstalling the bow liner.
I haven’t decided yet wether I will repair the cap outside or move the hull outside and bring the cap into my garage. The balsa coring on the casting platform was all shot and has been removed. The coring at the bow is still pretty good, but that will go also and all will be replaced with divynlcell.
Almost 4K in materials so far, including about 13 gallons of epoxy, so original cost estimates not looking to accurate, but no surprise there.
