Old 06-07-2021, 07:42 AM
Default For Sale 1973 23' SeaCraft
Transaction ID: 3K189641M5724521U
Charleston, SC
$48,000
Questions here would be great but best contact if interested is Reelescape1@yahoo.com.
I do not need help selling.
Possible partial trade for SeaCraft 20’ MA ONLY.
Boat runs low 40’s WOT around 1.2mpg. Cruise high 20’s around 2.6 mpg propped as is.
This boat has been fished. There are stains. There are stress cracks. There is dock rash.
1973 23’ SeaCraft (I’ve owned since 2006).
Re-fitted in early 2011 by G-Crafts Marine in Awendaw, SC (Bobby Ghelkin) including:
- Transom replaced (Boat Panel wood).
- Deck replaced and raised ~ 2”. Deck drains thru Gemlux SS transom thru-hulls.
- Added 2’ x 3’ bilge access and rear bulkhead oval access hatches. Bilge has storage for two 5 gallon buckets.
- Sunshine Tanks 3/16” aluminum fuel tank (118 gal) epoxy coated (not foamed), new fill and vent hoses double clamped. Tank grounded/bonded. Clear access hatch under console.
- Painted Awlgrip Ice Blue and Matterhorn White. Bottom painted 2021 for the first time as it’s slip kept now.
- Approximately 30 gallon transom bait tank with blue gelcoat inside, blue led light, clear and fiberglass lids, and 800 gph Piranha pump. Pump is mounted to a flanged seacock inlet that also feeds a Parmax washdown pump discharging from bow hatch.
- Hermco twin fiberglass bracket/swim platform with SS telescoping ladder.
- Full sunbrella, under top cover that may go one more season.
- Custom aluminum hull vent protectors.
- Bennett hydraulic trim tabs
Electrical/Electronics:
- All tinned marine wiring with shrink terminations, Blue Seas switch panel (breakers), ACR battery switch in SSI cabinet, ACR charging relay, led nav, deck, red/white under t-top, and spreader lights.
- Two Duracell AGM group 31 batteries in boxes under console.
- Guest on-board 110V charger.
- 117W Battery Tender solar charger for cranking battery only mounted on t-top.
- Garmin 2210 (ancient by today’s standards but works) with antennae/ratchet mount and extension on t-top.
- Furuno 585 with Airmar thru-hull B60 transducer.
- ICOM 504 vhf (distress wired thru gps with MMSI) with antennae/ratchet mount on t-top.
- Powder-coated aluminum E-box.
- Kenwood am/fm/cd, amp (ancient by today’s standards but works) in E-box with two JL speakers on console side.
- JRC 2kw radar (ancient by today’s standards but works) in E-box. Dome mounted on powder-coated aluminum strut.
- Dual 2000 gph Rule bilge pumps on switches (staggered height).
- Electrical and flanged seacock grounded/bonded to Guest Dynaplate.
- Ritchie compass and 12V outlet
Deck:
- Aluminum t-top with Weblon fabric, four vertical rod holders and two kingfish rod holders. Top previously had a sight tower and aluminum base plate is there but no tower.
- Lee’s telescoping aluminum outriggers with Rupp “1/4 turn” mounts.
- Three-piece curtains with front zip window and full side zip wings stored in Sunbrella bags under gunwale.
- Twelve Lee’s COB rod holders in cap.
- Two aluminum tulip transom mount rod holders for seating backrest. These are thru-bolted with ¼” aluminum backing plates and enough for planer use.
- Five Lee’s aluminum horizontal rod holders under gunwales.
- Birdsall twist gaff holder.
- Custom transom seating with backrest (easily removable).
- Front of console seating.
- Birdsall leaning post with fixed backrest, five tulip rod holders, four beer holders, footrest, and under-seat storage.
- Full bolsters
- 65 qt Yeti on Cooler-Slide under LP.
- Bow storage net with two type 1 pfds (included).
Engine:
- 2017 Yamaha 300 (digital controls) with approximately 210 hours installed March 2017 and under warranty until March 2022. (Starter failed last year and covered under warranty is the only issue I’ve had).
- Seastar hydraulic steering.
- Powertech four blade OFS SS prop and matching spare.
- Yamaha fabric cowl cover.
Trailer:
- 2011 Road King, SS fastener and led light package.
- Kodiak SS disc brakes on all wheels.
- Torsion axles, brake rotors, Goodyear Endurance radials added/replaced Spring 2019.
- Radial spare (new) with quick-connect hub.
