Old 09-14-2021, 12:01 PM
I made the passenger side bulkhead separating the deck area from the cuddy area with 1/2" CC honeycomb and a couple layers of 17 oz. biaxial on each side. It is quite stiff and not having to worry about corners made it relatively easy. Then I made the seat/hatch covers the same way. Lots of edges meant filling the honeycomb with thickened epoxy and then wrapping glass tape around, several layers thick. More work than I expected, but plenty strong again and fit well.
I am planning on making the entire face of the helm where the steering pump, electronics and everything else will be attached to ensure it is plenty strong. Then I was figuring the frame for the rest of the helm box with Coosa. Maybe I can see if I can locate some more Coosa locally. I found the three panels I have used off Craigslist for $660. That's about one panel now with shipping.
I like the idea of making my own G10 style glass board. That should be easy enough. I have found the 17 oz. material ends up being 1/32nd of an inch thick each layer. 12 layers won't take long to do.
Thanks for all the tips and suggestions. Much appreciated.
Old 09-14-2021, 05:51 PM
jbass03 jbass03 is offline
If you still have any scraps of demoed boat(the original side of the deck liner work great) you can stack them and use thickened epoxy to stick them together to make cheap G10.
