Old 11-15-2021, 06:28 AM
bgreene bgreene is offline
Original Sceptre max rating was 400 or 500 HP ?
Water must have gushed up the scuppers if twin 1,000 + lbs of motors on the back .
But with 300 and 350 outboards now on these boats might eventually find someone rigging a 450
Old 11-21-2021, 11:54 PM
The heaviest outboards before 1980 weighed under 400lbs.
A 1981 merc 225 weighed 363lbs. The OMC two thirsty fives were 396lbs.
By comparison a single 250/275/300 Verado weighs 700lbs.
Old 11-27-2021, 10:54 PM
Both the twin outboard 23' SeaVette and the twin outboard 23' Savage were made at least one year with a factory 600 HP max rating.
I never rigged one with more than 470 hp, though.
Fr. Frank says:
Currently without a SeaCraft
Old 11-29-2021, 02:01 PM
So 800 lbs of twins “ faggetaboutit” water must have shot up scuppers with a couple people in back . Seems scupper / floor original design wasn’t quite right .
Old 11-29-2021, 04:30 PM
Actually, there is/was a deflector in front of the scuppers that prevented that underway.
Fr. Frank says:
Old 11-29-2021, 09:10 PM
AND it creates a "vacuum" to drain even faster! - Genius!
Old 12-02-2021, 11:04 PM
Underway fine but that’s not when the boat sinks !
Old 12-03-2021, 09:58 AM
The down scuppers accept a standard 1” drain plug that keeps water from flooding the decks when the boat is heavily loaded or if equipped with over weight power
Old 12-04-2021, 12:11 AM
So what happens if …..
1. it’s raining hard,
2. or take on a wave
Without draining scuppers the boat sinks unless manually bailed fast enough - or specially rigged top side bilge pump ……
It’s just a boat - some designs are good, some not so good .
I believe several have raised floors and re positioned scuppers even when rigged with single outboards.
