  #28
Old 04-04-2022, 04:38 PM
joshmon71 joshmon71 is offline
I prefer marine exhaust hose (black stuff) to the white hose....heat it up with a heat gun and can bend it a bit as well. i use it for everything > white hose...but prob overkill. I also believe in 2 stainless clamps each end, orientated so each nut is on opposite sides. again overkill. Use some soap to help get hose onto the stainless fittings....
tip - I get clogs up on my limber holes as the 4 stringers are tabbed to transom....mainly the outermost section, something to eyeball here and there on a trip. these are the little weep holes to drain water into bilge go thru each stronger. if talking about water evacuation..
1977 Seacraft, Armstrong Bracket
275(chipped 250!) Verado
Merc Rev 4 17P
