  #38
Old 07-02-2022, 04:59 PM
You got me nervous so I went out and checked. All is good.
The tape method worked great. Thanks to all for the recommendations. I stuck little squares every 6 inches or so all around to hold the cloth in place. Then I wetted out the cloth as I figured saturation and getting to the substrate would be easy. It was. The glass stuck so well I was able to pull most of the tape off and finished wetting out the spots. I just checked on it and there are a few pull aways from compound angles around the strakes, but nothing a little grinding and filling before putting the next layers on can't take care of. No run out from the vertical or upside down positions. The epoxy is already hard after just 4 hours or so. Fastest I have seen it set.
Tomorrow will be some clean up then more laying glass. I am happy again.
