Old 07-07-2022, 11:11 PM
So I think I finally have the helm finished with wiring.
This only the items that are not switched (vhf, fishfinder, stereo) will have their own switches on the device but fused through the power supply.
This took a little bit of work. But my OCD is pleased. It should be easy to install and troubleshoot should I need to
You can see I daisy chained the grounds on a row with light loads. However the top row with bilges, PTT, and cig lighter adapters are individually grounded.
I used 12awg for grounds. And mainly 14 awg for the rest but some 12 in app loads.
For clarity Red is fuse block to power on switch.
The orange is switch to load. I plan to put them near each other. The wires are in same order as switch rows and should be able to install them in corresponding order, hopefully.
