Old 10-31-2022, 09:29 AM
wgscott329 wgscott329 is offline
Post away...interested about the cracked Keel...did you have the original wood keel still in the boat? freezing temps have been blamed for expanding and contacting of the water logged wood keel in the past.
This is the second cracked keel I have fixed, and I’ve seen a few others with a nearly identical crack. It seems the 23 has a hard spot in the keel, forward of the center wooden stringer, before the bow eye. I basically grind a ton away on the inside, lay a bunch of glass on the inside, and then grind back to my fresh glass from the outside to eliminate all the bad spots. Easy fix if the boat is fully apart. I’m not a fan of the wooden center stringers, so they have been removed from both 23s and the 25. The 25 will only retain 2 of its original 7 stringers by the time I’m done.
