Old 04-14-2003, 07:04 PM
Default Re: 23's Front hatch drain holes.....
Reel Smoker, I am confused- my fwd hatch has a thru hull that I use as a live bait well. In order to get it to fill with water I simply get someone to stand forward until it fills with enough water then plug it up. To drain it remove the plug and put the boat in gear and it drains. I dont know how you would drain it either with it plugged because of the rainwater [img]images/icons/confused.gif[/img] I havent noticed water leaking thru- I recently removed the fitting and the bare area under the plastic thru hull had some type of epoxy around it and I think water-proof. I 4200'ed the new fitting back in place.
