Old 04-16-2003, 09:52 AM
Hooper Hooper is offline
Default Re: Transom Mounted Transducer Placement
Tim D-
Nice idea about the starboard, I can see how that would help in placement. I think I will give that a shot, thanks for the tip.
Miles,
I hear ya about the smooth water, it is important so that you don't have to come off plane to scan the water beneath you. I have some vacation time next week and I hope to have the time to do this project then!
-Hooper
Old 04-16-2003, 02:22 PM
ScottM ScottM is offline
Dieter Sprockets
Hoop,
I mounted my 'ducer to the inboard-most side of the 2nd chine (see pics on the 23' page). I wanted it as deep in the water as possible without getting too close to the engine. As it turns out I don't get any reading beyond 18-20mph so either it's too far out of the water on plane or there is too much intereference by the engine. It's not the end of the world though since we also have an old Koden color CRT with a thru-hull 'ducer that reads at all speeds.
Old 04-16-2003, 03:47 PM
TUGBOAT TUGBOAT is offline
Might as well do it right the 1st time,Thanks for asking this ?.(nice 20)
I would prefer to 5200 etc, to the Hull NEW transom ! Can lexan be siliconed/5200 etc.? is starbaoard better ! I will screw the td on it so there goes Force , which one holds screws better ?
Scream'n Reels' [img]images/icons/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 04-16-2003, 04:17 PM
SECF3114M73J SECF3114M73J is offline
I shoot mine through the hull, works better than any transom mount I've tried. Gives a good picture at crusing speed. The less junk on the transom the better IMHO.
Old 04-16-2003, 04:38 PM
Eric McNiff Eric McNiff is offline
SEC - can you elaborate on that? I am trying to decide between a transom mount and a thru hull. Where did you mount it - in the bilge close to the bottom of the bait well?
Do you use a standard bronze thru hull transducer?
I heard you are supposed to mount it in a reservoir of oil (vegitable?) so the signal has something to be transfered through? Or can you shoot right through the hull?
I had my doubts about the performance, but when I read your reply I am having second thoughts.
Thanks
Eric
My wife does not care for the 2 boat theory
Old 04-16-2003, 08:23 PM
Jon G Jon G is offline
Hooper I put mine(20') right were TimD did and it works great. Slightly inboard of the center of the seconed running plane. The only time I have a problem reading is when I cut a hard left and get a little air under it. Tim nice boat BTW. Capt Brad Lexan and 5200 is whats holding my gas tank in so I'm sure its strong enough to hold a transducer on. I think I might try to mount mine that way when I redo the transom, the less holes the better!
I support the I'm glad I can afford one boat theory!
Old 04-16-2003, 10:49 PM
I'm going to mount the Garmin td right where Ya said,Thanks for that info.It came with a transom mount,
I also have a Furuno chartplotter,The td shoots thru the Hull.I bought this unit from a friend.It was mounted shooting through the hull,w/clear silicone,It was removed then replaced using a white silicone ? He said it did not work as well.Is there a trick or placement for a shoot thru hull ? I really don't want to put a HOLE thru the hull.I would really love to put in the bow/angle towards the bow SONAR !!!! Ok back to reality.
www.frenzie.com
