Old 06-24-2019, 09:30 PM
NaturalHigh NaturalHigh is offline
Default 350
How does she perform in reverse. I talked to a guy thatAdd a 300 on his boat and changed over to a 350 and said With the duel props reverse was much better control
Old 06-26-2019, 04:52 PM
castnetcracker castnetcracker is offline
Heres a picture from the keys last week. Wish i had my leaning post backrest installed at the time of the pic, it would have been nice to have the extra 7 rocket launchers
Old 07-17-2019, 05:11 PM
Oldboat Oldboat is offline
Default Engine height
Sweet boat. I just put a 300 Suzuki and bracket on my 23 and fighting a porposing issue. I was wondering if you had any issues and how many inches between you AV and keel. Any info would be a great help. Thx Keith
Old 07-17-2019, 05:50 PM
TBubrick TBubrick is offline
Default how much is the cost differential 300 vs 350?
the performance is pretty nice it seems..
Old 07-23-2019, 11:56 AM
wont be over at the boat this week but about 6-7" above the keel (bottom of bracket is 4" above the keel). the lower unit and props are totally different so you'd be better off comparing to other members with a 300. Sounds like maybe a weight issue but i still don't really porpoise with a loaded yeti 110 against the transom and 100 lbs of ice in the fish box behind the leaning post. trim tabs will help but will only be a bandaid fix that will rob you of efficiency. any weight you can put up front will help with these hulls and you'll really notice it in 2-3' chop.
you may also want to check for a hook in the hull with a straightedge on the keel.
Old 09-19-2019, 10:45 AM
GetLit GetLit is offline
Has anyone bolted a 350 ( or motor over or around 700lbs) up to just the transom, no bracket?
On a 23
Old 03-16-2020, 07:42 PM
Surfnski Surfnski is offline
What is you minimum speed on plane?
Old 03-26-2020, 03:07 AM
69Seacraft20 69Seacraft20 is offline
Wow that’s great! Post a YouTube video ��
