Hey Hoop , just go to a plastics shop give them the measurements and and tell them which side to bevel. When I bought mine they were happy to do it and no extra charge.Took about 10 minutes.I actually took them my old console panel and he just copied it. I also got thinner starboard that I should have. I believe I got 3/8" but I would get 1/2" if I did it again. I think mine ended up costing 16 bucks.
"Lifes too short to own an ugly boat" |
Hooper
I was originally going to use Starboard ended up with Fiberglass(made a recesed panel). 1/4 is way to thin. I ,bought a sheet of 3/8 & it was border line.Go 1/2 the first time .This stuff works easier than wood.You WILL have a MESS of lil black plastic around.My only concern with using starboard was how to seal all the joints , electronics , gauges etc. , without leaking water in.?? I was told pvc glue would bond it ? Someone here will have an answer on this I'm sure. I used all black gauges , electronics.I really like that blacked out look. I opted for what I have. Scream'n Reels' [img]images/icons/cool.gif[/img]
http://www.frenzie.com/frenzielogoline.GIF www.frenzie.com http://www.frenzie.com/custom.htm "Classic SeaCraft" Lures 1983_seacraft_master_angler.]htm My wife and I had words, But I didn't get to use mine."?" |
Miles-
So you went to a a shop who sells starboard and asked them to cut you a piece to size, is that right? That's interesting... Then all you had to do was decide where to cut in your electronics right? Capt. Brad- Have you sealed the openings yet? I wonder how the PVC glue would be and it you may not want that making a seal with your expensive electronics... or am I missing what you wrote? I do agree tho, it will make the console look much better and give it a real finished look. -Hooper |
At about half the price of starboard is another UV resistand HDPE plastic called Seaboard. I've bought it at J Freeman in Dorchester, MA. They were easy to deal with and the stuff seems the same as starboard that I've worked with. They will cut to size. http://www.jfreeman.com/cpg_seaboard.html
Most glues and caulks won't stick to these products. If you need to prevent water from leaking in you might want to use plumber's putty to form a non-permanent gasket.
Best regards, Roger http://members.cox.net/rhstg44/Misc/...go%20small.jpg 1979, 20' Master Angler |
Heck I dont think 5200 will stick to it. There are several "plastics" shops in this area and they are happy to cut and bevel anything you want. The stuff is very slick. I didnt seal mine with anything,actually I even thought about,the original one wasnt sealed either. Getting the original screw holes lined up with the new plastic was the hard part.
Hooper
I did not go with starboard because of the sealing problem,Down here We can get 5"s of Rain in about 5 min.s did'nt want to run / leave the plexi installed,also i do not cover the boat after washing I let Her Dry out then cover.Sometimes(In the Summer) It will Gulley wash & thats all I need is water inside the console (AGAIN).Built a New instrument panel(mold) of the original wood.Lil deeper.Used a flat primer(self sealing)(NO GLARE).SEALED !Drain tubes in the bottom edge. ![]() Scream'n Reels' [img]images/icons/cool.gif[/img]
Brad.....NICE WORK ..... Do you have a panel covering everything when not in use ....similar to Regulators console??
Is it that cover/panel you are talking about here... "did'nt want to run / leave the plexi installed" You did this work didn't you ....very professional looking ..well done Gluing starboard ...think you need to use "their" stuff...and from what I've heard is very expensive ...but it is the only thing that will bond it together properly.... I think its a solvent that fuses or "melts" it together....Would be interesting to see if PVC cement worked or an acrylic cement....that fuse thing together [ November 17, 2003, 11:26 AM: Message edited by: Scott ] |
