George,
I'm familuar with 2 different processes. One is with regular sand blast equipment and soda beads used as a media. I have also saw soda beads attached to plastic (Looked like small fly bait). It is used around here to sand blast diesel engines that have been offshore in the oil field. The second is used with a waterblaster. The soda solution is in a drum, has a hi-pressure injector pump that injects the media into the water stream. I watched this being done to an aluminum hull house boat barge at a local dry dock. It really worked well. The whole rental set up was on a trailer that could be towed with a P/U and rented by the day. They also load as many drums of media as needed on the trailer and you just swap the injector pump.
David Bienvenu |
To sidestep your how-to question just slightly, I've seen good and bad results from soda blasting. It all seems to depend on who is pulling the trigger. The examples I've seen that were less than perfect were scary at best - very deep pits where the person hesitated for a brief second or two (much deeper than a few coats of paint would fill). If you are planning on doing this yourself, be very very careful not to go too deep.
![]() Quote:
Sadly, no. It was on a '79 SeaCraft 23' CC that the owner was trying to save a few pennies by renting the equipment and doing the job themselves. I saw the boat after they brought it to a professional boat yard to cover up the damage [img]images/icons/frown.gif[/img]
HA GEORGE
YOU WILL LIKE THESE SITES. http://www.jacksonmarine.com/jackson...nmarine_6.html http://www.enviro-strip.com/index.htm I HAD JACKSON DO MY 23 COST ME 600 AND FOR ME IT WAS WELL WORTH IT. THE SECOND SITE TALKS ABOUT HOW TO DO IT YOURSELF. FELLOW-SHIP [img]images/icons/cool.gif[/img] |
