Old 08-12-2004, 12:39 PM
Default Re: Engine Troubles
Otto I hear your wife calling you... You said you changed the coil wires.. Did you change the coil?.. Your motor has a trigger, because what do you think makes the power pack work in time with the pistons, you don't have a cam shaft and a distributor...Weak spark is your problem...Forget about the fuel till you get good spark on all 4 cycl....
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
