Ok, I'm finally getting the transom transformation rolling. I had to wait for that darn CSC member named "Mark" to get his boat finished so I could start mine [img]/images/graemlins/grin.gif[/img]
Here's some updated photos. I thought my transom was pretty solid as there was no flex even thou it was bleeding a little at the cap, But as you can see, it was definately time for a makeover [img]/images/graemlins/frown.gif[/img] I feel that if it was not for the amount of glass in the engine splashwell and baitwell holding things together, the transom would have had to be replaced years ago [img]/images/graemlins/crazy.gif[/img] I will be taking more pictures as I go ![]() All hatches / Rocket Launcher, Trim tabs etc were taken off. ![]() The Motor was then de-rigged and removed. Notice the water weeping out of the holes of the trim tabs and cap piece... ![]() The Engine well, side buckets and the Transom were cut out. Look at all that black wet wood [img]/images/graemlins/shocked.gif[/img] ![]() At least 30lbs of mush and wet stinky wood filled the trash can ![]() Inside the Transom. You can see the where the wet wood was against the glass ![]() Starboard Inside ![]() Port Inside ![]() This was the biggest piece of solid wood found but it was still very damp. Notice the hole dead in the middle behind where the engine mounted. I had filled it in around 1986 when I replaced the original 1979 200hp. Go back a few pictures and you can see the white Marine Tex held up and kept that section from water intrusion. Originaly this hole was the overflow drain for the molded in floor baitwell as this boat was rigged for twins from the factory [img]/images/graemlins/laugh.gif[/img] ![]()
Chuck,
Glad to see things moving along. Looks like Riley is helping out too. [img]/images/graemlins/smile.gif[/img] |
Chuck are closing the transom and cutting out the well? What did you do with the cap, cut the back quarters off?
I am still trying to figure out the best way to do the Vette's transom withougt too much cutting of things I want to keep. The SF was a piece of cake, room galoor. ![]()
http://lecharters.com '76 23 SC CC I/O '86 20 Aquasport 200 '98 15 Boaton Whaler Dauntless There's more but w/e |
Chris, I hope this answers your question?
I got chuh. I need to do some figuring cause I need seating back there and I am not sure if I want to loose the well or go over top and leave storage. I really don't need the transom wells, so I may cut them out too.
Chuck-
Looking good there. Brings back not so distant memories. Looks like you are pretty far along. Keep the pic's coming Strick
Chuck,
As I have said more than once in the past - your boat is in the right place for the redo, you will be happy with the finished product [img]/images/graemlins/smile.gif[/img] |
I forgot you were down chuck- looks like you are moving right along though!!! One of these days Im going to have to stop fishing and do the total thing like you "true craftsman" on this board do. keep sending the pix!!!! [img]/images/graemlins/smile.gif[/img]
bte- love that 2nd "waterborne" shot in your first post!!!
"Lifes too short to own an ugly boat" |
