Old 04-13-2005, 07:35 AM
elpez elpez is offline
Default Re: 4 stroke weight on 1998 21?
I have drilled the transom on my 1998 21' (to install the Armstrong ladder bracket) and there is NO WOOD there, only the "green stuff" which is the composite material. Will let you all know my inpression of the e-tec after this weekend.
Old 04-13-2005, 10:35 AM
warthog5 warthog5 is offline
I highly suggest that you follow these instruction's for a composite core install. The Green stuff is Divenacell.
http://bertram31.com/proj/tips/sleeving.htm
Old 04-13-2005, 05:59 PM
Thanks, very informative and will use it if I ever drill into the transom again, did not use the pvc but enough 5200 to seal the Divinacell
