Old 03-03-2006, 11:10 PM
warthog5 warthog5 is offline
Default Re: 1976 Seacraft master angler / Ft Laud, FL
You can also use the same hose you have on the livewell pump, but 1 1/8in is harder to come by. We had to buy 50ft of it from the manufacture. [min. order] We used it on 3 diffrent boat's.
We bought it from these guy's.
http://www.nexgenhose.com/
Old 03-04-2006, 03:11 PM
RS RS is offline
I've had a problem with that livewell type hose kinking in the tight spaces of a 20. Especially if you need to make a few bends. If you have to bend against the normal lay from the spool it flattens too easily. This spring I've got to change mine out for the sanitation hose.
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
Old 03-04-2006, 05:10 PM
Scott Scott is offline
I agree. I dont understand why they still make/use that plastic hose !! This is what I have on my bilge pumps. 1.125" ID smooth bore hose with a coil in it to stop any chance of kinking or collapse. Its not cheap but given the alternative of a split bilge pump hose dumping water back into the bilge, its the right price !!!!
