Old 01-13-2007, 11:08 AM
TUGBOAT TUGBOAT is offline
Default Re: SeaCraft Emblem
Its reversed! The bottom of the Mold is actually the top of the emblem.Couple of ways its testing & Timing(Cruicial).
Leave the mold inverted & apply the film on top when its almost cured & still tacky,2 Lay the film on a hard surface & invert the mold with resin on top of it,Press on the mold to seat the film.How bout a 3rd-Just mix a Fine Chrome metallic flake to the mixture the pour? It'll be shiny-Bet a Coon would play with it!First way is the best... But from eXperiance Unless Your gonna Monunt them on something & hang-em' on the wall They'll snap.They(original) look like the typical "POT METAL" emblems.
Tug
Too bad Ya don't have another one??? I'd try a couple of things but don't want to jepordiZe the Original!
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 01-13-2007, 03:30 PM
If you know a potter, I think you might be able to press it
into some clay and then fire it. Then use the ceramic "mold" and fire it again with it full of
bronze or brass shavings. My babe does pottery and has a kiln.
Old 01-14-2007, 09:39 AM
Capt. Brad,
I wish I did have another emblem as I would be glad to send it to you for experimentation. Your concept sounds interesting, could you PM or email me with a little more info?
1bayouboy,
I used to do some clay work & actually have some clay. I'll try working with it today & see how well it picks up the detail.
I really do appreciate all your ideas and input.
Thanks.
Old 01-14-2007, 12:37 PM
You'd need to start with fairly soft clay, and maybe wet the emblem to make it release better......but my lady says it should work and the ceramic mold could be used with any softer metal......lead, brass,,,,
Old 01-14-2007, 02:09 PM
GradySailfish GradySailfish is offline
Hey there, there's a fella on classicmako called Scott C who runs a plastics CNC shop. He makes swtich panels, place cards etc for mako guys, so I'm sure he can make something like that for you. Here check out a link to some of his work.
Classicmako Hull Place Cards
Classicmako Switch Panels/Builders Plauques
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
