Just a couple of thoughts here . . .
Prop . . . You can try a different prop. Some props give better lift in the bow. Has the console been moved forward? Where are the batteries? (mentioned above) Where does the cavitation plate line up with the bottom of the hull? -------------------------------- Anchoring in 3ft chop . . . is a bad idea all around in a 20ft boat. If you are doing this let out lots of scope and clip off to the bow eye instead of a cleat. --------------------------------------------------------- Also trim tabs won't help you get the bow up. |
