Old 05-18-2008, 01:32 PM
Default Re: 1996 Johnson 115 HP V4 - Low Compression one h
I`ll second that. It`ll smoke like a civil war battlefield. That`s normal. Don`t to forget to spin the engine with the plugs out to evacuate the cylinders of the powertune. Liquids wont compress and you don`t want to bend a rod or worse.
Old 05-19-2008, 10:24 AM
StrangeBrew StrangeBrew is offline
Thanks Frank and Go Fast Sandman. What do you mean by "spin the engine with the plugs out"...Not sure how to do that?
Old 05-19-2008, 07:32 PM
Thr spark plugs removed and turn over the motor to evacuate the liquid as it will not compress and "hydraulic "the motor. Trim down for this.
GFS
Old 05-21-2008, 09:01 AM
Have you tried this yet? We'd love to hear that everything came free and you're up and running.
Fr. Frank says:
Currently without a SeaCraft
Old 05-23-2008, 10:01 AM
I did spray the cylinder with the PowerTune...It's been sitting since Sunday. I plan to run it this afternoon and check the compression again...Keeping my fingers crossed. I will let you know what happens. Again, thanks for the info!
Old 05-25-2008, 06:49 PM
I would spray all the cylinders! Even compression across the board is what you want. I`ve only been a lucky owner for a year and have learned much from this site. That`s what it`s all about. Learn - share. Rinse and repeat as necessary.
Thx to all who make the sacrifice on this glorious Memorial Day,
GFS
