The work on my 78 20' MA is progressing. Deck, paint etc should be done in a month or so. I need a motor. I have a 1980 150 Merc and would like to buy/trade for a later model 175 Merc (I can't afford a new one). I would like to keep in the $4-5K range max. Any thoughts on where to get a rebuilt motor? Trade in my 150? etc. THX!
DaTNGrizz |
I don't know where you are, but I have billybob's old Evinrude 225 plus NFB steering if you are interested.
I am in Lenoir City TN...but that is too much motor for my 20. Thanks anyway, I appreciate the response.
DaTNGrizz |
Pretty light response...no recommendations on where to get a rebuilt or good used 175 HP motor? THX!
DaTNGrizz |
Hey Bud,
Easy now, easy. Slow down. Most of the members here are saltwater folks and you are at the western base of the Smokey Mountains, at least a few hundred miles from the east coast. I did a search on Google for a 175HP outboard for you and came up with this website you might want to check out. http://bbcboards.zeroforum.com/ It is apparently devoted to Bass Boats and may be very productive for you. I didn't register, so I can't give you a lot of info, but check it out and you might check out other similar sites. We all love our SeaCrafts, but keep in mind they are primarily a saltwater boats because of their superior ability to handle the water conditions found on open water. Try some of the more freshwater focused sites like the one I suggested and you might have some good luck finding that "needle in a haystack" you're looking for. If you own a Seacraft, cherish it! It will still run in freshwater too. Good Luck.
Getting home is more important than getting there! Plan accordingly! |
This is a follow-up to my earlier posting.
Keep in mind that looking for 175 horsepower outboard is a bit tricky. Most of our 18 and 20 foot models use 175 horsepower as an upper limit for power options. Our 23 foot models, on the other hand, rarely run 175 horsepower-even on the lower end of engine horsepower. If someone is running the 175 horsepower on their 18 or 20 foot boat, they're not likely to be looking to upgrade. There will be a few occasionally willing to bite the bullet and go with the newer technology such as the e-tec. The problem with that is that it just doesn't happen that often. Further, getting involved with a used motor at distances of 200 to 300 miles or more raises more issues than simply availability. Transportation, mechanical survey, negotiation and secure payment methods all come to mind. I also noticed your original posting was less than two weeks ago. Depending on how long you've been a member of the site, there are plenty of examples where searches for a particular piece or accessory has taken months if not years to complete. Take a look at some of the freshwater sites and you might have more luck or at least spread a wider net for your search. Further, if you can avoid it, it would probably be better to get a motor that has lived in freshwater rather saltwater. They tend a last longer than in fresh water. Again, good luck.
