![]() Here's a real kicker: both agree that TCW3 2-stroke oil, when used with gasoline that is 8-10% ethanol, will NOT protect the engine in any oil injection system that does not inject the oil directly into the cylinders. It absolutely does not workk well when pre-mixed with gasahol and stored in a fuel tank. If thats not working, what should we pre-mixers be doing?? ![]() ![]()
" I'm the one thats got to die when its time for me to die; so let me live my life, the way I want to". J. M. Hendrix |
Jerry Schiaccitano of AAA outboard in Crystal River says you need to have a fuel stabilizer designed to work with ethanol, and add it every time you add gas. Mercury (Quicksilver) makes one, and StaBil has just introduced a new formula for using with ethanol fuels. Both work to inhibit the hydrophilic properties of the ethanol, as well as inhibit fuel additive separation.
![]() Quote:
Tim, I read about it in an 2nd hand online report on the effects of ethanol on two-stroke motors. I was researching and surfing on the issue of the effects of ethanol on TCW3 oil in premix fuel after a friend lost compression on 5 out of 6 cylinders on his '88 Johnson 225 while running premix. The mechanic blamed it on ethanol in the gas.
I don't remember the web address where I read it, though. I had just clicked through on a link from HotBot, (which is my search engine of choice). I just now spent 20 minutes trying to find it again. I am quite sure about the name of the testing organization, though. The report named the Southwest Research Institute, which is the largest independent research body dealing with oil, and petroleum products in the world. I will keep trying to relocate the report, which was in .pdf format, and I believe was dated in February. (Yes, I already checked my temp files) As I recall, it also said the amount of accumulated condensate was more than 3 times the amount that could be expected with just regular gasoline in a half-full tank.
