Old 04-24-2009, 10:06 PM
fdheld34 fdheld34 is offline
Default Re: having engine trouble???? suzuki DT 115 outboard.
I am just plain broke ...I dont think your Suzuki has an exit hole for the air to escape when you fill it. I remember my neighbor had a Suzuki and I remember him tilting engine up and down and adding more fluid...somebody else will chime in here..I am not a mechanic either!!!!!
Old 04-24-2009, 10:45 PM
stumpie2 stumpie2 is offline
not quite sure about suzuki but i know yamaha tells you to trim engine completely up use the support "legs" to hold engine up then release pressure on hydro. system by loosening manual release and fill till it barely runs out of fill hole, replace plug, tighten manual release, and run trim system up and down a couple times air sould work itself out... i may be off a little but im telling you from my best memory
http://i729.photobucket.com/albums/w...ictures007.jpg
I DONT KNOW, BUT I'LL GIV'ER HELL TRYIN!!!
