bushwacker, how fast will your 20 go w/ the 150?
50. His hole shot at 70% throttle is mindblowing too. Seemed like 2 seconds to plane. Very impresssive indeed.
GFS |
The Opti's are just fine now as well, when you go to the V6 all the engines will be close in weight from 150 to 200, thats why I suggested the 115 HO - V4 and as much HP as the 130. The next big factor is the lower unit, the HO's are designed for smaller lighter hulls and it comes with the high performance Lightning gear case which has a smaller foot print and therefore faster too. I think it comes in about 370lbs so about 50 lighter than Bush's 150
I follow alot of boat forums on the net, Etec's and Opti's are seeing the least issues of all. The Etecs will also run @ 100/1 oil ratio and no dealer servive for 300 hrs, which is a fact not hype. Plus I can get you a good deal on Etec's if you can put it on the boat
![]() Quote:
Snookerd |
I have the 175 Pro XS Opti, which is a tweaked version of the normal 175. I can spin 6000 rpms versus the normal 5600.
![]() Quote:
I used to get slightly more speed with my old Mercury XR4, running a PowerTech 15.25"Dx16.5"P 3-blade. The motor was reman'd to about 190hp, but I couldn't get that kind of mileage. The ETEC is impressive.
hole shot is pretty decent.
200 ft. lbs. @3000 rpm, yeah that`s ok I guess. You can also winterize it in 15 mins by yourself.Winterize? Saw a rerun of Ship Shape tv and they toured the factory. You should see the size of the spider gears in the lower unit. Massive. BRP is the best thing to happen to Evinrude. |
![]() Quote:
