Old 07-21-2009, 02:24 PM
Tiny Tiny is offline
Default Re: how did you cut out foam?
There is a product called Motsenbocker's Lift Off Silicone Latex Caulk and Foam Sealant Remover, I have not tried it for your application. Do a search, you might squirt some down the cracks and see if it will help the bottom release.
Just a thought. Let us know the results if you try.
I bought some at BOW in Riviera Beach, FL.
Old 07-21-2009, 09:47 PM
spade shovel
36' Yellowfin
1972 20' seacraft 140 suzuki
Old 07-22-2009, 12:01 AM
BigLew BigLew is offline
Depending on how big a piece you want to cut out at a time, you might want to use a buck saw blade. (The kind that is mounted on a steel frame similar to a hacksaw and is used for limbing out a tree or cutting firewood when you don't have a chainsaw available.) Make sure you make some sort of handale to protect your hand. Cutting a paint stirer in half and riveting that to the sides of the blade is one idea that comes to mind. To cut the blade, you could use a grinder I am sure and to pop rivet it and drill holes I'd would you use a stone of some sort that would normally be used in a dremel tool. You could mount that in the standard electric drill for what you're going to be doing. I don't think the standard drill bit will easily drill through that blade.
To use it, just work it under the foam and start the sawing motion, keeping the blade flat against the fiberglass and your hand end up just a bit for clearance. The blade will flex enough to allow this.
Just a thought. Good luck.
Plan accordingly!
Old 07-22-2009, 11:38 AM
Endured maybe? suggested using a prerssure cleaner and blast it out. Messy , but effective I believe.
GFS
Old 07-22-2009, 01:46 PM
After doing a small 16 ft boat a few years ago I can tell you no matter which way you go it's a royal pain
Old 07-22-2009, 10:45 PM
alexh alexh is offline
Sounds like it might just be a long day. I think I will just grab the sawzall and a shovel and go to work. I do like the idea of the bucksaw but by the time I get it some kind of system down I might just be better off with the sawzall.
Has anyone filled a boat with foam without the deck on before? I plan on slowly adding more foam until I just get above the stringers and cut/sand the rest flush with the stringers. I was thinking of covering the exposed foam with resin before I put the new deck in. Waste of time? Let me know what you think. This is my first time and I'm not too worried about messing anything up, but I definitely do not want to create anymore work for myself.
I appreciate the feedback so far!
-alex.
Old 07-23-2009, 08:19 AM
Putting a coat of resin on top sounds good until you think about eventually having to remove it, or part of it, later on. That resin over the top could end up costing more time and aggravation than its worth. Maybe a coat of some kind of paint or something just to seal it. I would be very interested in other members thoughts on this question.
Plan accordingly!
