BigLew- The spray rails are teak and as far as I can tell original equipment. I must say they work very well. If you would like I can measure them and send you a profile. They are consistent in dimension their full length and rounded on either end. Just walked out to the boat and measured them, They are 1 1/2 inches wide and 1 inch thick flat stock- screwed or bolted on the outboard edge and plugged with 1/2 teak plugs. There is no place in the boat where I can see if it is a screw or bolt. I would hope it is a bolt but if not they have lasted very well. This may be a much cheaper solution. The rail starts 42" from stern and runs all the way to the bow. I did put a 3/8 radius on the outboard top edge before painting. You could probably benefit by steaming the stock before bending in place or on a mold but I have never steamed teak only oak and mahog. I wonder if the new PVC white house trim would work? Tough to glue. Thank you for the compliment on the boat.
M |
Michael,
Thanks for the offer, but I have a 23' Scepter and I am a while away from the point of putting spray rails on. I've been looking to redirect my consulting/contract business or look for a job since my lead consultant/partner is in the process of "changing directions." What we had been doing really requires the two of us to really make it work.
Getting home is more important than getting there! Plan accordingly! |
