Connor
I saw Carl at the OFF2009 Raceboat gathering and specifically asked him about how much water ballast would be appropriate for your boat. He said Potter didn't build the boat the way he designed it, and that he wouldn't bother with the ballast tank. Your observations are interesting though. Sounds like placing gear as far forward and as low as possible would be worth playing with. Did you get those props fixed? Sounds like you could go to higher pitch, now that you found that earlier run did not get to full WOT! I think that vacuum gage will help you find the "sweet spot" combination of optimum throttle/drive/tab trim. Keep us posted on what you find out! Denny
Well, she was on a trailer awaiting cleaning and winterizing so I got a few shots.[image]http://
Connor,Here is a pic showing risers per your PM [image]http://
Outstanding pics! Just what I needed to show the welder.
Thanks Connor |
Brandon-
Interesting that your boat's scuppers are in the stern while mine are a foot or so forward of the stern in the sides of the hull. strick
Mine are where Brandon's seem to be. They exit through the side of the boat. Much of the time the deck tilts slightly down going forward, so scuppers more forward sound like a good idea.
Brandon,thanks again for the tab idea. Those are even larger than what I had on the Seabird. Looks like there is enough surface area to damp the roll quite a lot. I'll find out. Denny, that vacuum gauge is the cats meow. You have made a convert. Haven't fixed the props yet, but I think I know what I want. Same engine F5s(stainless) was 4600 rpm in the Seabird. These are D2s (aluminum) and turn 5050 loaded. The volvo book says 200-250 rpm for each size larger in duoprops and go one size larger for equivalent in stainless. That gives me a F4 which should give about 4800 loaded. Max rpm range 4600-5000 on this engine. I'll have several conversations with prop guys first, but thats what I think for now. Does being in the middle of the max rpm range with the boat loaded close to the max its likely to carry make the most sense? One thing I don't understand, maybe someone can shed a light. The volvo book says most efficient cruise speed is 15-25 percent below max speed at max rpm. That results in real high rpm that the vacuum gauge says is too high and looks too high to me as well. Any comments? Connor |
Strick,
It is interesting about the different scupper locations. I think Nuthinfancy's are even more forward of yours. I guess the ones that were set up with the huge twin engine box the full length of beam would've had to have had them farther forward. Quote:
At rest, with no passengers, ours drains towards the transom. With two in the cabin, it drains forward then back then forward....JK it drains forward then I go to sleep ![]() Enjoy the new tabs Brandon aka WTMFI guy |
![]() Quote:
I'd get those aluminum props fixed and run them again before making a final decision on SS props. As for rpm at Max load, being at the middle of the range is probably pretty close. High end of the range is probably easier on the engine, low end may give a little better mpg, so splitting the difference is a reasonable compromise. I know Fr. Frank says to prop for Max rpm at Max load. I'm sure that's true for 2S outboards that run needle bearings, have no valve train to worry about, and love to rev. Lugging an engine (high load at low speed) increases cylinder pressures and temperatures, which increase loads on pistons, rings, bearings and valves while the low speed REDUCES oil/coolant flow and pressure, so it's generally better to let 'em rev! It's probably true for 4 strokes as well, but they can have valve train issues (resonant vibration that can wear or even break valve springs, dampers, studs and rocker arms if you spend much time at a critical speed). 200 rpm isn't a big deal, but I'd try to find a Volvo engineer, and ask him if you should prop it for 4600 or 5000 at max load, and why. If there is a critical speed, say 5100-5200 you'd like to know that too! [/QUOTE]One thing I don't understand, maybe someone can shed a light. The volvo book says most efficient cruise speed is 15-25 percent below max speed at max rpm. That results in real high rpm that the vacuum gauge says is too high and looks too high to me as well. Any comments? [/QUOTE] That 15-25% recommendation is a very general statement and not necessarily right for a specific boat. It should probably say MAXIMUM cruise rpm, not the most efficient speed! You're right, the vacuum gage is a much better indicator of best efficiency, and I'd guess 3750-4250 rpm is pretty close to 5-7" vacuum or max continuous power for that engine, if it had such a rating. If you're gonna take that boat to the Bahamas, you'll be burning enough gas that I'd spend the money up front to get either a Floscan system or the Volvo equivalent of the I-Command/Smartcraft system if there is one. It'll eventually pay for itself by helping you to always run the boat at optimum trim, plus it's good to know exactly how much fuel you've got left and not have to depend on a gas gage that may not be very accurate!
![]() Quote:
yeah mine was origionally a twin sterndrive and had the huge box. and my scuppers are almost directly below the shorepower plug, inline with the bulkhead between the engine compartment and fuel tanks, almost directly below the end of the side windshield
http://i729.photobucket.com/albums/w...ictures007.jpg I DONT KNOW, BUT I'LL GIV'ER HELL TRYIN!!! |
