5 star all roller 5200# carring 7300# gross love it
we need a lifeguard at the gene pool |
Single axle Continental aluminum float-on with 6 inch wide bunks for my 20SF. Launches and drives on easily. Just have to be faithful on the hubs and bearings every six months. I also use stainless hardware everywhere I can. I replace the galvanized bolts, braces, etc., whenever they need it with stainless. Just make sure to grease the threads before you torque the stainless bolts down!
I would highly recommend the aluminum with bunk route. I had a roller trailer for my old 20 which I thought was fine, after going to an aluminum bunk for my new 20, wow how easy can it get? Just make sure if you go that route to get the forward vee bunks, they really make a world of difference.
I do not keep my seacraft in the water and trailer 100% of the time and I really, really love my bunk trailer. ![]()
2001 23 Regulator 2006 F250 Yamaha |
![]() Quote:
If you have a decent ramp to launch your boat then a float on is the way to go. Rollers can be a pain in the butt.
![]() Quote:
![]() ![]() My tandem axle Continental has all stainless hardware galvanized axles, hubs and lug nuts. Stainless Buddy Bearings. 7 Grease-able 12 inch Stoltz Keel rollers 8 Grease-able 4 inch Stoltz donut rollers 10,000 lb. Power Winch 3/16 inch stainless cable. Stainless lanyard cable to operate winch "solo" from 2 X 12 inch rough sawn Cedar walkboard to the back of the trailer!!! About the greasable shafts, 5/8 inch galvanized bolts that are 14 inches long. (excess cut off after head of bolt welded to the galvanized roller frames) Drilled approx 5 inches into the head of the bolt then tapped for a zirc fitting.... This trailer works on any ramp anywhere. I can launch and load by myself anytime!! If you take care of it, It will take care of you! ![]() ![]() ![]() ![]() ![]() ![]() Even works as a park bench for Doodlebug, Skipper-T & Bushwacker.... ![]() ![]() ![]() ![]() Do not get me wrong, I also have Float-On trailers as well. But for me, The roller trailer is my favorite. Oh yeah, This trailer is a 1980 and still going strong.. See ya, Ken
See ya, Ken © |
![]() Quote:
1979 23 SCEPTRE TWIN 150 Opti's/GAUSE BUILT BRACKET |
i have 4 "service" trailers,all roller.all urethane rollers too,never a problem with rollers,upkeep is minimal,give 'em a squirt with the hose...bearings hold up longer,due to the fact,the wheels are never submerged.bunk trailers in an area with a good tide swing,make it just about impossible to load and unload in a low tide.also,the aluminum trailers,these will float.personally,i would never own,nor do i reccomend bunk style trailers to customers...
do not let common sense get in your way |
