Old 03-03-2011, 04:03 PM
McReef McReef is offline
Default Re: Epoxy vs Vinylester
My impression was that you can can poly on top of poly, or epoxy on top of poly, but you cannot add poly on top of epoxy (no chemical bond).
I think you are on track there. From what I can gather, while epoxy will cure just fine over poly (and bond aggressively), the chemical makeup of epoxy actually inhibits the curing process of poly and vinyl resins. The lack of bond is due to the fact that the newly applied poly/vinyl resin never fully and properly cures at the interface of the two materials.
David Robertson
Old 03-04-2011, 08:53 PM
Finster Finster is offline
Just my 2 cents but I've used both and I'd stick with poly or vinylester. Epoxy is strong but annoying to work with, try laying something up on a vertical serfice lol, good luck.
Remember, these boats are all made with poly and are stong and solid as hell. You not going to reinvent the the wheel by using epoxy.
Btw, I have gallons of system 3 if anyone wants it...yuk!
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 03-06-2011, 02:51 AM
I will take you up on this offer. I could use some epoxy to make my fishbox. Give me a call to set up shipping 252-342-2509 Thanks
Old 03-07-2011, 11:39 AM
dbiscayne dbiscayne is offline
poly & vinylester are fine on a new build, when laminating wet on wet layers of material, but you'll never get as good of a bond onto something thats already cured. Thats where epoxy has such an advantage, a great secondary bond. It's also easier to mix, doesn't smell as bad, & has a longer working time. But you can't put gelcoat on top of epoxy.
Old 02-26-2013, 03:20 PM
liam liam is offline
Hey Dave based on the speed you are working at I would be more concerned with which product has the longest shelf life
Old 02-26-2013, 06:07 PM
hugo hugo is offline
befor starting my rehab on my 20 SF i went round and round trying to find out which is realy the best to go with and in the end i used poly, the price was realy the deciding factor for me. im sure the epoxy is a better product but in the end but i kept being told it would be good for a liftime.... but i hope its not my last boat so if its good for another 10 plus years thats ok with me. as for molding in a bracket that is using no fasteners i would go epoxy.
Old 02-26-2013, 10:26 PM
Vinylester and polyester aren't the same thing. I had it explained to me that it can be thought of as similar to a polyester at one end, and similar to an epoxy at the other end of the chain. With properties in between.
My one class in composites was back in the 1990's so take it with a grain of salt. I do know that the curing agent is more like polyester.
I used vinylester last year, and it sticks to polyester and epoxy. I used it as a primer coat between epoxy and a polyester gel coat, and it is tenacious. I hear it is often used as a barrier coat on epoxy sailboats.
I like it enough that I want to use it more. It is safer than epoxy from a sensitization standpoint, higher performance than polyester, and compatible with either.
Old 02-26-2013, 11:09 PM
Nitrile gloves. Nice properties.
Old 02-27-2013, 08:40 AM
I have herd that the epoxy is more flexible than the poly but was wanting to know if done right will the poly hold up to a lot of flexing. Don't want to have stress cracks develop if the boat is getting a lot of pounding in a ruff water conditions being ran hard. The poly I can order a 55 gal barrel for $975 and the epoxy is over $2700. Also I have herd that poly has a shelf life of only a year or so. That worries me on getting the 55 gals. Will it last longer if it is in a controlled environment and if so what temp dose it need to be stored at?
