Old 04-24-2011, 06:03 PM
Default Re: Cheap bad idea
I will keep that in mind. I definitely won't swap them until it runs right. I was going thru the fuel system today and found lots of water, cleaned it out and it ran better, but not good yet. All I did was drain the float bowls and get fresh gas(ohol) to it. #1 isn't getting much fuel. A little carb cleaner when running and it perks up. Some say the strainer/filter on each carb should be looked at. When it isn't snowing up here I will look at that.
The 175 ran ok on muffs last year, so I guess that's the backup plan.
