Any info about undress thebbow eye should it be an empty void or a deck if the foam is removed ?
The area under the bow eye is a open area, I keep my small anchor in there, its finished with gel coat with a drain hole to the bilge in the bottom. What a mess someone left you get that stuff out of there Good luck with your project.
I support the I'm glad I can afford one boat theory! |
Thanks sei g they added the foam here I was wo dering was thee foam under the decks originaly? I also heard that the stringers have no wood in the older years I'd this true?
ya, it tru, no woody, jus foamie in da stingers.
diggy alla foamie outa boxie an u be bettar. sammy |
Anks Sammy good to know
but is there floatation foam under the decks or nit and this I'd whybtheboast owner added some ? |
mr mike
ubetter dig that crap out and see wtf iz under dem decks. da wood & water looks lik mr possum be livin in der hatchs ok bye sam |
