So I guess I need to be running WOT all the time
Naw It's just the prop that came with the motor. As the budget get better I will look for a "all around" prop Most of the time you run in the mid range anyways I know that you have extensive knowlege on props what do you suggest?? |
Jorge, I think the best easily available all-around prop is used is the Quicksilver Mirage. I would also suggest either the 17" Pitch, or 18" Pitch, assuming you have the 1.85:1 gear ratio lower unit. If you have the 1.65 gear ratio (which would be unusual), then the 15" or 16" pitch is in order.
