Originally Posted by Bushwacker
Originally Posted by ElBichoMalo
Why would it only work with epoxy? I was planning polyester...like I have used on everything so far. Is there a reason that that method won't work with polyester? . . .
The bond strength of epoxy is about 2000 psi vs. about 700 psi for polyester, so you definitely get what you pay for! For repairs where you're bonding new stuff to old polyester, I think epoxy is the only way to go. The cost of materials is sort of a nit if you figure your labor hours are worth anything at all!
Along the same lines, epoxy is not as brittle as polyester. It will give more before cracking. So a threaded hole in an epoxy plug will not be as likely to strip out as the same approach with polyester. That doesn't mean you have to do your layup with epoxy, just your plugs.
Dave
