Old 05-11-2015, 08:23 AM
CoreyTrx CoreyTrx is offline
The boat is coming out great. Have you thought about spraying the gel coat? You will save tens of hours of sanding if you spray over rolling. Plus it's a lot easier to get even coverage spraying then rolling. You can get a cheap gun from Harbor Freight that will work good. I spray it all the time with some duratec or patch aid mixed in. You don't need a huge compressor either. I have a craftsman that I think is a 30 gallon and it keeps up fine. It will really save you tons of time. Keep up the good work.
Old 05-17-2015, 09:06 AM
afishin82 afishin82 is offline
I would love to spray it but have had nothing but frustration the last couple times I sprayed gelcoat. I would have to do some sort of primer to ensure I don't get pinholes and sand that anyway. So just figure I will try rolling and sanding. I've gotten pretty good at sanding anyway....it's my favorite thing ever!
Old 05-18-2015, 09:08 PM
72potter20 72potter20 is offline
I used interlux vc performance epoxy on my boats bottom. Turned out great and can be applied over gel coat. Doesnt stain at all.
Old 06-12-2015, 07:28 PM
Well done sanding and buffing and am very happy with the results! I put 1 coat of wax on and was thinking about putting another coat on. I'm not sure if it's necessary or how long to wait to let the first coat harden up. Any recommendations?
Old 06-12-2015, 07:44 PM
Couple pics after first coat of wax.
Old 06-15-2015, 01:38 PM
ricciprice ricciprice is offline
Looks good, plan on doing the same thing, will be mixing with duratec and shooting tho, my brother is redoing a small whaler right now and he tried shooting gel with a dump gun but had tons of orange peel, was sanded down and reshot with duratec and gel and boy does it lay down, sanding time was cut at least by half if not more, duratec will make lay down
Old 06-18-2015, 08:34 AM
I tried duratec before and didn't prime the boat first. Ended up with tons of little pinholes. I guess if you a good prime coat on it would help with the pinholes. I will try it again on the next project.
Old 06-18-2015, 08:35 AM
Anyone have any tips where to start with a prop for the 200hpdi???
Old 06-21-2015, 10:06 AM
WillyC WillyC is offline
Mercury Mirage Plus 19p. I'm running an old carb'ed Yamaha 200 on my 1975 20' sf. Right at 400 lbs it does great on my boat. I can only get 5200-5300 rpm out of it at wide open but I think its mounted a little low.
Old 06-21-2015, 12:19 PM
I'm gonna try the yamaha reliance 19 sds. A guy with a 200 4 stroke is using it and he said he's very happy with it.
