Hey Danny about time you got here.
I didn't take it out. It's a 1984 did they come with one.
I'm pretty sure all the Potter hulls had it - it's just a 12' 2x4 on edge wrapped in glass from the transom fwd. Glass is about 1/4" thick. I don't know about the later years. Has the boat been partially redone before?
Found some time to get back to work on the boat.I glassed a few holes at the bottom of the stringers so the foam I pour in would not leak out.Than I poured the two part foam in the stringers. My concern is that the foam i took out seemed to be much denser than the new foam I put back in. Could that be a problem?
nice job on the stringer foam.I would think the density would be alright as long as it is closed cell stuff...I was wondering if there was originally foam poured outward of the stringers toward the chine?Mine is an 85, and had foam between the stringers and chine, to the hull sides.I put it back that way,I guess if water can get in there,it can get out...hopefully.It seems to be sealed off pretty darn good,dont see how water could get in there, except from the stern by the rigging tubes...any thoughts?
The density is also effected by temperature when you pour it. Optimum is 70 degrees for pouring. Pouring at higher temps will give you less density and fill up more volume. Probably better than pouring at lower temps where you would need a lot more liquid for the same capacity.
Sunshine was close to that a few years ago for mine. 3/16", 118 gallon, 5052. I would use them again for sure. Shipping sucked, but they were great.
Any thoughts on a poly tank? Anyone used one on a larger 90-100 gallon size?
Mine did have foam on the sides. But I am not putting the foam back in. The temp was in the low 80s when I poured the foam.
I cut out part of the new deck and I glassed the bottom of it and while it was drying I started to cut out the transom. Check out the pic I wanted to do only that part of the transom but do you guys think that's a bad idea
